Panasonic DVDRV60 (Multi-Region)
Discussion in 'Blu-ray & DVD Players & Recorders' started by ascotford, Mar 6, 2001.
  1. ascotford
    ascotford
    At the end of this month I plan to spend £400 on a DVD player, I was wondering if anyone had the "Panasonic DVDRV60 (Multi-Region)" player and have heared any bad reviews about, or any known problems.
    I was going to buy the Sony DVPS735 but I have found that it does not support RCE disc's.
    Regards
    Andrew Scotford
  2. NigelL
    NigelL
    I've a multiregion RV60, and I have a problem with the region 1 playback (non RCE) in that I get a small amount of flicker on the edge of my screen.
    I'm still trying to find out what the reason might be. I have been told that the machine can play RCE discs, and other than the above problem the picture is wonderful.
