Panasonic DVD-S35 and DMR-E30
G
glebecs
Hello,
I have just plugged a Panasonic DVD-S35 player in (bought a year or two ago and never used) and unfortunately the remote control seems to be on the same frequency as my DMR-E30 DVD Recorder. I cannot find a way to change the frequency used by the DVD-S35 but have no manual for the DMR-E30, any idea if I can resolve this?
Thank you.
G
glebecs
OK, I found the answer, on the DMR-E30
1. From the remote, press SETUP
2. Press ARROW UP or ARROW DOWN to select "Setup" and then press the RIGHT ARROW key.
3. Press ARROW UP or ARROW DOWN to select "Remote Control Code" and then press ENTER.
4. Press ARROW UP or ARROW DOWN to select the code (1, 2, or 3) and press ENTER.
5. While pressing ENTER, press and hold the numbered button (1, 2, or 3) for more than 2 seconds. Note: the factory default code is 1.
6. Press ENTER.
Apparently this is the procedure for most Panasonic Recorders.
Andy
Podcast: LCD TVs for Movies, Laser Projectors, RIP Ennio Morricone, AV & Movie news, B+W Matt Damon
