Panasonic DVD S 97 and sanyo z3 help
Discussion in 'Blu-ray & DVD Players & Recorders' started by andya, Jan 16, 2005.
  1. andya
    andya
    Oct 25, 2002
    2,432
    48
    manchester
    +35
    borrowed my mates panny dvd player to hook up to the z3 projector ,he forgot the remote control i tried using qed component cables but the picture i get is in black and white ,can anyone help the dvds i had were crouching tiger pal and finding nemo pal.do i need the remote to tell the panny its in component
  2. edinburgh160
    edinburgh160
    Hi, it should pick up automatically the input you are using, as long as you have it on the correct output on your screen.
    Incidentally, what region is CTHD ? Not all Panny S97's come multi-region.
    You really need the remote as it can be a fiddly player to get used to.
    cheers
