panasonic dvd recorder + Hd and cable problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by hklein, Sep 26, 2005.
  1. hklein
    hklein
    I have recently bought a DMR-EH50 (1 week old)
    My home system is via a Pace digital cable decoder (telewest).
    problem is when I record the cable signal onto the HD on the recoder- for the first 10 minutes or so of the recording operation the picure colour distorts for a anything up to 4 or 5 seconds as a time. After 10mins or so the problem does not re occur
    When recording the direct tv signal with the cable box off the problem does not occur
    it appears I either have interference from the cable box or a problem with the hd unit
    any ideas or suggestions
    thanks
    h
    any ideas anyone
