Panasonic DVD players region free hack now available
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Incure, Jul 12, 2006.
Thread Status:
Not open for further replies.
  1. Somebody
    Somebody
    Aug 4, 2006
    19
    I did exactly the same on a BNIB DMR-EX85 using an iPaq last night. :smashin:
  2. hemis
    hemis
    Hi, guys!
    Would you, please, help me? I have:
    DVD player Panasonic SA-HT335 from Panasonic Home Cinema System SC-HT335;
    HP iPAQ Pocket PC rz1710
    The player is R5 coded so I can't watch R1 DVDs. I tried Virus' hack with TV Remote Controller but it didn't work :( I installed TV Remote Controller, downloaded ccf file with the hack, opened it in the program, pointed my IPAQ to the DVD player, pressed RC1 button and waited for several minutes, nothing happened. What was wrong? Thanks in advance!
  3. Woziak
    Woziak
    Jan 26, 2006
    87
    +7
    Try to play with the distance between the ipaq and the device until it responds...
  4. Incure
    Incure
  5. hemis
    hemis
    How can I find out what type of system controller is in my player? Thanks.
  6. hemis
    hemis
    OK, thanks a lot, guys! I did it :) I downloaded Tom's 342v4 firmware update, burnt the CD, updated the firmware, entered the combination "Enter, 6, >=10, <<, 0, Audio, 8, 1, Subtitle, 4" and got the region-free and RCE-free unit. Hereby I confirm that this way works for SA-HT-335 DVD player. :thumbsup:
    P.S. it is written at this site "You can check which version you have by pressing 7 on the remote and at the same time PAUSE + OPEN/CLOSE on the player". This was no good for my unit, the "7 on the remote and at the same time PAUSE + STOP on the player" combo worked instead.
  7. DIlha
    DIlha
    Nov 15, 2005
    5
    Om my iPaq 1650 there is no way TV Remote 5.5 would load the hack ccf file! I can´t figure out why!:( :( Other CCF files load normally.
    Could you please tell me the TV Remote version you used?
  8. hemis
    hemis
    TV Remote 5.74 I took it from the link given at this site.
  9. FluffyLob
    FluffyLob
    Oct 25, 2004
    103
    28
    +33
    Hello all,
    I apologise if this has been answered already, but I'm (fairly) sure it's not specifically covered either here or on the dcevolution site.
    I have an SC-HT855 that I'd like to region-free, using IR output from a PocketPC. From reading this thread, there seems to be several opinions with this and other HTxxx models-
    - Don't try it, you'll probably brick it with an FT or ST error (steve1971)
    - It's confirmed working on an 855 by virus using his CCF file - correction - just noticed this is confirmed on the 885, not 855
    - 855 works at a different device code (eoinf)
    - HT500 didn't respond to IR (wale)
    - There is no way to return a HTxxx stuck in ST mode to normal (steve1971)
    - HT355 works with a modified firmware then standard remote (hemis)
    Can anyone help me make sense of these differing viewpoints? My biggest concern is trashing the unit and getting it stuck in ST mode - but I'm not even sure if that is a genuine concern. Any guidance appreciated :)
    Chris
  10. Incure
    Incure
    Nice summary Fluffy, to quote myself:
    But I think, in this case, what eoinf posted earlier (855 works at a different device code) is true. If the standard code doesn't work, try to find the right service code (or as eoinf for it).
  11. FluffyLob
    FluffyLob
    Oct 25, 2004
    103
    28
    +33
    Cheers Incure,
    I did read that section of your post, but the amount of conflicting info specifically about the HTxxx range still made me cautious. As it turns out though, impatience got the better of me, and I tried the hack last night :)
    Sadly it failed, with the 855 not responding at all, as wale reported.
    So, eoinf (or anyone else!) do you know the device code for the 855 - or - can you give me some pointers as to how I should uncover it myself? I'm happy to spend some time on this, I'd just need a pointer in the right direction to get started.
    Cheers,
    Chris
  12. Lewie
    Lewie
    Sep 15, 2005
    11,892
    Folkestone
    +924
  13. macklij
    macklij
    Aug 28, 2006
    112
    +22
    I have just sucessfully done a DVD-LS5 portable player. It came up with the FT02 message as well. I used the cancel button on a normal Panny DVD remote and it reinitialised just fine.
  14. Lewie
    Lewie
    Sep 15, 2005
    11,892
    Folkestone
    +924
    Anyone?
    Is the >=10 button the same as -/-- ?
    What is the code for subtitles as its not on my remote?
  15. fidelityutensil
    fidelityutensil
    Mar 9, 2006
    28
    Does anyone know a hack for the Panasonic DMR-EX75?
    I've been looking, but can't find!
    This maybe due to stupidity, but any help would be much appreciated!
    Ta
  16. macklij
    macklij
    Aug 28, 2006
    112
    +22
    Will the hack mentioned in this thread not work? 'Someone' further up said it worked on the EX-85, which is very similar.
  17. foreigner
    foreigner
    I have tried the region free hack on the DMR-EH55 with no luck.
    I used the Laptop method and the remote.txt provided.
    I see the player reacting to the commands and even reseting but I still cannot play other region DVD ... (bought the DVD in region 1 and trying region 2 DVDs).
    I tried 3 times ... 3 resets ... no succes ....
    I must have done something wrong as I can't believe the hack to be working with all other models except this one ...
    Any ideas of what to double check ?
    Thanks,
    Foreigner.
  18. Steve1971
    Steve1971
    May 29, 2004
    76
    Halifax
    You are trying to play PAL DVDs on an NTSC Unit , You cant do that.
    Steve DVD Chips
  19. Hackeroonie
    Hackeroonie
    Dec 2, 2005
    252
    Cardiff...Wales
    +18
    Foreigner
    To Expand on this a little..well a lot actually.
    Some Players Made for the Region 1 Zone ..which is an NTSC Area..are not what is known as Dual laser
    This means that the Player is not capable of reading PAL at all and it appears that your Region 1 Player is one of those ...and Steve1971 would know this as he is far more experienced in these matters than me.
    The Main Reason for this besides cost is that most DVD Disks are Released in the Region 1 Zone first ...so the demand for Multi Region capability is supposed to be Less in those areas.
    And it also appears that the practice of single laser (NTSC Only) Players seems to be mostly in the domain of the "Top End" Players rather than the "Budget" Players.
    From what your post Says
    The Hack has worked ..and will play all Regions ...but NOT PAL Disks if you were to purchase for example a R2 Japanese disk it would play as Japan is an NTSC Zone
    So you will need to steer clear of European R2 and Australian R4 Disks as these are PAL Zones
    The Panasonic DMR-EH55 European (R2) or Australian (R4) models (if available in those areas) will be Dual Laser ... but sadly yours is not and therefore will not be able to play PAL no matter what.
    Hope this helps
    Hackeroonie
  20. Steve1971
    Steve1971
    May 29, 2004
    76
    Halifax
    Hackeroonie is on the right lines but is wrong to say it has anything to do with the laser , NTSC playback requires less memory that PAL playback so it's simply a cost saving decision to leave some electronic components out of NTSC units that are fitted in the dual format NTSC/PAL units.
    In the case of portable dvd units NTSC screens are cheaper so again Region 1units are sometimes fitted with NTSC only screens.
    Steve
    DVD Chips UK
  21. Hackeroonie
    Hackeroonie
    Dec 2, 2005
    252
    Cardiff...Wales
    +18
    Folks
    Oh well I was Close enough hehehe:D
    I did say that Steve knew more than me on the Subject :)
    And I was Right :D
    Cheers Steve :)
    But the basis of the thread was correct ..the player will not play PAL
    Hackeooonie
  22. foreigner
    foreigner
    Thanks a lot guys for the lesson, I appreciated the detailled explanation.
    Not so proud of my ignorance of the basics but ... at least I learned something !!
    Jeff.
  23. borland
    borland
    Jan 4, 2006
    152
    +11
    I've just hacked (with PSP remote) DMREX-95V (bough at QVC brand new for &#163;300) but no RCE playback. What's wrong?
  24. davb
    davb
    May 7, 2006
    I used a laptop to do this successfully on my DMR-EX95VEBS, which is presumably the same model as yours.
    Did the unit restart itself and display the "HELLO" message after you had entered the codes. If it didn't, then it probably didn't receive all the codes correctly.
  25. borland
    borland
    Jan 4, 2006
    152
    +11
    the unit did restart and it plays back R1 DVD but not RCE protected. I've found one RCE protected dvd in my R1 collection - The 6th Day with Arni. When you try this DVD it shows world map with regions and a message which says something like "this is nothing wrong with your player. this dvd is not supposed to be used in modified dvd players...." that means that dvd is RCE protected. I wonder if anybody else has RCE protected discs and the same problem as me.
  26. davb
    davb
    May 7, 2006
    I will try some other discs to see if mine is the same.
    Is there any way of telling if a disc is RCE protected from the markings. I have some R1 and some R3 discs.
  27. davb
    davb
    May 7, 2006
    I have just tried Maid in Manhattan, which is RCE protected, and it plays fine.
    Have you checked to see if you have used the correct codes for RCE, and not just for Multiregion.
  28. borland
    borland
    Jan 4, 2006
    152
    +11
    I thought that the IR hack was the same for ultiregion and RCE... pls correct me if I am wrong
  29. davb
    davb
    May 7, 2006
    There are a number of posts in this thread relating to the problem you have. Look at #39 and #40 by bigguy283 which may be your problem.
  30. Incure
    Incure
    An update for the Panasonic S49 and S295 users, Tom made a breaktrough by releasing the first Macrovision and CGMS disabled firmware for these players! Now you can record (commercial) DVD's to any source, digital or analog.
    You can find the new firmware here:
    http://www.dcevolution.net/panasonic
    Please remember that these kind of hacks or only possible trough modifying firmware, never trough a remote control hacks.
Thread Status:
