Panasonic DVD A100 Macrovision Disable (genuine reason!)???
Discussion in 'Blu-ray & DVD Players & Recorders' started by Paul O, Jan 16, 2001.
  1. Paul O
    Paul O
    Nov 2, 2000
    481
    UK
    +21
    Hello,
    Yep, I have a Panasonic DVD A100. Had it since the begining of region 2 time, and I havent had a problem with a single disc on it (yet!)!!
    My question is this - I have got the player modchipped for Multiregion, and was told by the dealer that he though Macrovision would be disabled. It isn't however.
    Does anyone know if it is possible to remove macrovision using the menu system at all, or will it only be removed by using a different chip??
    Cheers,
    Paul.
