Panasonic DSB 30, 40 or 50
Discussion in 'Satellite TV, Sky TV & FreeSat' started by garyward, May 25, 2004.
  1. garyward
    garyward
    Is there much difference in the receiver tuner when being used in weak reception areas for the above models? Concensus seems to be that the DSB30 was/is best. Did they not use the same tuning technology in each model?
    Thanks all.
