Panasonic DP-UB450EBK 3d problem
SyStemDeMoN
I have had this player for a year now and I remember the last time I tried to play a 3D disc on it I had problems.
I have updated the firmware and tried different cables and such. The cable I use atm allows DV 4K to the tele so I am assuming it would pass 3d also.
I have the player direct connect to TV and the audio out to the amp.
When I try to force a disc into 3d i get a message saying that the TV is not compatable.
It is an OLED C6 and is 3d. It has not had any work done to it as I know if I had it repaired then a 3d panel would not of been put in.
I can get 3d to work on the TV through ps4 and such. Just not this player and its doing my nut in.
Anyone have any ideas ??
SyStemDeMoN
any help ?
goingoingong
Are you talking about problems with a native 3D disc? or trying to force a 2D disc into 3D?
SyStemDeMoN
SyStemDeMoN
But I think I have found a work around. Not the best solution but still . . . .
I have to plug my hdmi video out into the amp and send the amp to TV.
It cannot do 3D with 2 hdmi running. This is a major issue as my amp passes 3d no problem but still its an oversight from Panasonic I think.
SyStemDeMoN
Clem_Dye
Yes, but as I don’t have a 3D TV, nor am I ever likely to buy one, it’s a feature that I will never explore.
Oculus Quest 2 VR headset + Rotel A14 MkII Amp Reviews & Best of the Month
