Panasonic DMREZ25EB-S
Discussion in 'Blu-ray & DVD Players & Recorders' started by imigix, May 5, 2007.
  1. imigix
    imigix
    Jan 27, 2007
    277
    west yorkshire
    +10
    Help I am using rw discs after I make recording in order to play back on another player it has to be finalized
    Does this mean I cannot use the disc for recording again or can I reverse it
    My philips recorder lets me take a rw disc from it and play in a denon or sony without finalizing
    Also when I put a disc recorded in the philips in the pana.it will play it but I cannot get the menu of disc contents on the screen
    Hope someone can help thanks
  2. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,145
    +7,093
    You will be able to use the disk again by formatting the disk... which will erase all previous contents.
    Re the menu issue... I assume this is a +RW disk you are referring to?
    Panasonic machines are basically -R / -RW machines with +R / RW support bolted on. There are some differences in these formats which make things like this arise.
    If you finalise the disc in the Philips it may work.
