Panasonic DMREX77 and 26LXD70
Discussion in 'Blu-ray & DVD Players & Recorders' started by martinjconnolly, Sep 11, 2007.
  1. martinjconnolly
    martinjconnolly
    Hi All
    I've just set up my new EX77 with a Panasonic 26LXD70 TV. I've a couple of questions that I can't figure out from the manuals:
    1 = I've only used an HDMI cable to connect the two. Should I also connect them with a SCART cable? What extra function would that give me?
    2 = According to the manual, if I have the TV on standby and press "guide" on the EX77 remote, it should switch on the TV. It does that and displays the EX77's EPG. However when I select a programme it shows that briefly before switching back to the native TV display. I have power on prefs set to "AV" on the telly so what's going wrong?
    any tips greatly appreciated
    ta
    Martin
  2. SuperSeven
    SuperSeven
    Oct 29, 2005
    576
    28
    +30
    Using the scart won't add any extra functionality. If anything it's just likely to confuse the TV as the TV may auto-switch to the Scart signal rather than using the HDMI.
    You need use HDMI if you want to output a 720p/1080i upscaled signal.
