Panasonic dmres20d -is it any good?
the baron
Established Member
I havent entered the world of dvd recorders and i am still using a video to record.is this an easy machine to get to grips with for a first timer?.has the freeview got now and next for all channels without turning over?.can you record from a vcr? thanks.
ajp558
Established Member
>> Setup was easy, watching & recording freeview was easy, but due to poor(ish) manual it took me a little while to get used to chase-play/timeslip while recording to DVD-RAM.
>> Yes, use the info button & then you can scroll through the info for the other channels while watching the current one.
>> yes, using SCART in. Its easy but of course there is macrovision protection if you are hoping to transfer bought tapes with protection built in.
Cheers,
AJP
ROYOLD
I purchased this DMR-ES20D because it had the freeview plus analogue integrated tuner. Its low power use. It only uses 25 watts (imagine that - less than a standard lightbulb) and, of course, its support for DVD-RAM. I use this machine connected to my Topfield PVR which has a 160GB HDD. Perfect combination. I am well pleased with the ES20D. I also have the E85 and E60 machines.
http://panasonic.co.jp/pavc/global/diga/europe/es20_es10/specifications.html
🎬 Poirot 3, Spider-Verse, Psycho Collection & Mask of Phantasm 4K + best/worst animated Batman
Back
