Panasonic DMRES10 Recorder
nwgarratt
I am looking at purchasing one of these (I know it is a older model). I need RGB in which the DMRES15 does not.
I can't find any decent specs for this. I need to know what formats it plays and records onto. Does it record onto +RW?
Does it have component progressive output?
nwgarratt
FrankS said:
You can go to the Panasonic web site http://www.panasonic.co.uk/customer-Support/download-centre.asp
and download the instructions they tell you what connections and what formats you can record to. I have the DMRES25 and I'm very pleased with it, but I don't think +RW is very well supported by the unit. I use DVD RAM and -RW
I already been there which is why I posted here. I am reading elsewhere it records onto -RW but the manual only saids -R and RAM can be recorded.
I would just like a list of confirmed formats that play and record.
C225
i have this model and can confirm it plays all formats and can record onto all formats except +RW.
Also it does have the component progressive output.
Hope that helps
