Quantcast
Panasonic dmres10 question
AVmaster
Yep, there shouldn't be any confusion as the fact that it is Multi-Format means that you can record and play both +R & -R.
D
DGtal
It even says +R on the front of the machine, look under the 'DVD RECORDING' slogan, there it is! Panasonic didn't state +R on their site details for the machine and that may be where the confusion came from.
