Panasonic DMRES 20 freeview
Discussion in 'Blu-ray & DVD Players & Recorders' started by flash53, Aug 6, 2005.
  1. flash53
    flash53
    Aug 5, 2005
    43
    Does anybody know if the new Panasonic DMRES 20 freeview model has a R.F. modulator built in it so I can send the signal through a aerial cable to a bedroom. :lease:
  2. DRAMBO
    DRAMBO
    Feb 15, 2005
    157
    West Yorkshire
    +5
    I haven't seen the panny ES20D but as it's just an ES10 with a freeview tuner added it should have an RF modulator just like the ES10.
  3. llg
    llg
    yes it does have an R.F. modulator
  4. flash53
    flash53
    Aug 5, 2005
    43
    Thanks for your quick replys thats the one I will have then if I can wire up to other rooms to watch d.v.ds. and freeview :clap:
