Panasonic DMREH50
Discussion in 'Blu-ray & DVD Players & Recorders' started by Carloto, Oct 24, 2005.
  1. Carloto
    Carloto
    Anyone got any views or opinions or reviews on this unit? I am considering purchasing this but would welcome any feedback from current owners or thoes in the know!
    :smashin:
  2. MattDX
    MattDX
    Jan 21, 2005
    4,528
    +368
    Bought mine from Richer Sounds about 5 weeks ago for £270 + £60 for 3 year warranty.
    Great bit of kit, really pleased with my purchase. Recordings are excellent and the unit is very quiet. Good editing tools and very user friendly - check out the reviews in the forums to see for yourself.
    The only 2 things that I think let it down are:
    You can't automatically add chapters to a recording - you have to do this manually.
    When you record onto anything other than the HDD or DVD-RAM it will only record in 4:3. This sounds quite major but I only ever use the HDD so not a show stopper for me.
  3. Carloto
    Carloto
    Cool, thanks. I think I'll pop down to Richersounds at lunchtime then!
  4. troutmask
    troutmask
    I got one recently too - chapters are added every 5 mins or so when you dub to DVD (except at high speed, when chapter points you create beforehand are preserved), and the aspect ratio is preserved if you record in real time to DVD - but the widescreen designation is lost (aspect ratio is unaffected though, as far as I can tell). Aspect ration changed to 4:3 when dubbing at high speed though! Some strange quirks ....
  5. RAB67
    RAB67
    Aug 21, 2005
    177
    +8
    Mine died after 3 months - but has now been fixed. Back in the best-thing-since-sliced-bread category.
  6. lemondy
    lemondy
    The only problem I have with it is its slow response to the remote. But you do get use to it after a week or two. Other than that, it works great.
    There is also a detailed review of the unit at iRecordTV and at CNET .
  7. ROYOLD
    ROYOLD
    Jul 5, 2005
    3,898
    103
    Royton, Oldham. Lancs.
    +296
