Panasonic Dmreh50
Discussion in 'Blu-ray & DVD Players & Recorders' started by BENSONDOG, Oct 1, 2005.
  1. BENSONDOG
    BENSONDOG
    Anyone had any probs.with the Panny DMREH50. Mine`s 5 months old.
    Problem with unit whereby can only play DVD,unable to switch to HDD or SD.
    Unable to eject disk. Can access program check to record, unable to access direct navigator. Will play DVD then when hit stop button -unit goes into "BYE" mode.
    Checked all the obvious, Child lock etc. Powered off and left off for an hour (several times)
    Is it as bad as it sounds ??
  2. Archie Fax
    Archie Fax
    Nov 23, 2003
    233
    Kent
    +10
    If you bought it new, take it to a Panasonic service centre and it will be repaired free of charge.
    You kept the receipt I hope?
