Panasonic DMREH-50 Stuttering playback
tutu
I've owned the Panasonic DMREH-50 for a while now (80gb HDD and DVD Recorder). Lately it has been playing up - stuttering playback on hdd recordings (recorded off the freeview tuner). I was watching Alien Ressurection and it was the worst I have seen - it will play for 1 second, then stop, then 1 second, stop. It continues for 20 minutes when I just gave up.
Do you think formatting the HDD will help or should I send it back? Or alternative solution. Are they bringing out any new models (bigger hd, dual tuners, divx playback would still be nice).
maldonian
Freeview reception can freeze and stutter, so I would try recording from the recorder's own analogue tuner before condemning the HDD. (The EH50 hasn't got a built-in Freeview tuner, so I take it the Freeview tuner you refer to is a set top box or in your TV.)
aekostas
Also, what is your RF routing?
tutu
The attena goes straight into the DMRES-50 and then routed into the TV. Sky Digital is skipped.
maldonian
We might be at cross purposes. When you said 'freeview tuner', were you referring to the tuner in the EH50 recorder? (in other words the 'free' channels 1 to 4 (or 5) as opposed to the Sky channels)
Which channel was Alien Resurrection on?
