panasonic dmre55 ebs( dv in )
Discussion in 'Blu-ray & DVD Players & Recorders' started by den9112, Dec 10, 2004.
  1. den9112
    den9112
    Feb 8, 2004
    2,168
    83
    +341
    thanks to the reviews on this forum , i have decided to go for a panasonic . with a budget of 200 it seems the right way to go . my question is can i put my dv footage direct to the recorder i presume this is via a built in fire wire card . am i correct in saying i need i recorder with a dv in . hope it as one as it sounds like a decent recorder for the money . thanks dennis
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    A DVD recorder with firewire for £200 ! Now that would be a bargain :clap:
    Alas, just scart, s-video and component video inputs, I'm afraid. :)
  3. Nil
    Nil
    The panasonic e65 has a dv-in, but its about £50 pounds more.
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,220
    Argyll
    +2,267
    Someone on this thread has found one for about a £20 premium over the E55. If you want to record from a Digital Camcorder then the extra for the E65 is well worth it - plus you get a few other benefits: LPCM recording, PC and SD Card slots, JPEG Slideshows etc
  5. burcac
    burcac
    Yeah I ordered one of the very last ones in stock. Deals gone now (rub it in!)
  6. den9112
    den9112
    Feb 8, 2004
    2,168
    83
    +341
    thanks fo input will go for the e65. thanks
