Panasonic DMRE50 & 55 what is different??
Discussion in 'Blu-ray & DVD Players & Recorders' started by waz2004, Sep 25, 2004.
  1. waz2004
    waz2004
    Sep 14, 2004
    296
    +6
    Am I right in saying Panasonic DMRE55 is the current model which replaces DMRE50?
    It is just I noticed that sainsbury has the 50 model at similar price to 55
    :smoke:
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,722
    Warwick
    +2,600
    Yes - the main difference is the E55 has component output, progressive scan and DVD-Audio (2 channel) playback.
  3. waz2004
    waz2004
    Sep 14, 2004
    296
    +6
    so is the 50 model obsolete?
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,722
    Warwick
    +2,600
    Not obsolete, just marginally surpassed. If you getting a good deal on an E50 pick it up - but note you can pick up the E55 for £210 online (and about £250 in the shops) so don't pay over-the-odds for the E50!
  5. waz2004
    waz2004
    Sep 14, 2004
    296
    +6
    Just seen the 50 model at sainsbury at 250 squids. Think i will give it a miss.
    Is the Pan 55 or Pioneer 220? model sufficient for recording vhs tapes onto dvd?
  6. Rasczak
    Rasczak
    Apr 3, 2002
    21,722
    Warwick
    +2,600
    Either will do a good job. My preference would be for the Panasonic E55 as it has more features at the same price (the Pioneer 220 is closer in specifications to the E50, i.e. no PS, component, DVD-Audio). But if you need DVD-RW then the Pioneer won't disappoint.
  7. tbanks
    tbanks
    Sep 25, 2004
    12
    Just bought the E55 at Costco for £165 (inc voucher discount) they had it at under £200 list
    Almost worth paying the membership fee to get one....
    TimBo
  8. Jules
    Jules
    Oct 11, 2000
    5,585
    134
    +1,045
    but isn't that excluding VAT. I looked at this deal, but then realised with VAT its actually a tad dearer than Richer Sounds and isn't multi region.
    It can be had for less then £200 multi region if you shop around.... and you won't need to pay a Costco membership fee!
  9. dempsey
    dempsey
    But the costco ones come with the advantage of a 12 month Panasonic warranty where the multi-region richer sounds one doesnt, not sure I would buy a DVD recorder at the moment without the support of a manufacturers warranty.
  10. dude1971
    dude1971
    I had a Panasonic replaced by Panasonic and it was a multi-region one from Richer Sounds. Why do you say that they wouldn't support it?
    Regards
    Dude
    p.s. The other difference between the e50 and e55 is that use of thumbnails on your recordings, that's only on the e55/65 models.
  11. dempsey
    dempsey
    Because Panasonic officially don't offer a warranty on any unit supplied as multi-region. Maybe if theyre doing an exchange for one of their refurb units within warranty it wouldnt be checked as these exchanges are done through a third party company but any repairs wouldnt be.
  12. dude1971
    dude1971
    They exchanged for a brand new model, I saw the invoice from Richer. Then Richer took another week to multi-region it. DOH!
    Regards
    Dude
