Does anyone know how to get this Panasonic model DVD player enabled for multiregion use. Originally bought from John Lewis, so it is just Region2. Thanks.
You'll need to rent a special handset for approx £20 to £25. The Panny DVD Recorders cannot be hacked using the normal remote. http://www.avforums.com/forums/search.php?searchid=2301298 S.
Could you possibly let me know where I would start looking for a hacked remote - I have no idea you see! Thanks.
Try here and they work very well as long as you carefully follow instructions. http://www.multi-region.co.uk/index.php?manufacturers_id=22&osCsid=a17fb22d65757eb458f15534038ad697
You can search these forums for "panasonic hack", a google search for the model you have plus multiregion hack, the banner below, or the clasified section of a AV mag! An example thread on these forums that will help is: http://www.avforums.com/forums/showthread.php?t=240687&highlight=panasonic+hack
....Or perhaps I won't! Their number is never answered and nor are my emails. Can anyone recommend anyone else please? Thanks.
http://www.dvdchips.co.uk/ Never used them myself but do a forum search for dvdchips and you can see members' posts/feedback about them. S.
