Panasonic DMRE-55
Discussion in 'Blu-ray & DVD Players & Recorders' started by fuji, Sep 29, 2004.
  1. fuji
    fuji
    Jun 10, 2004
    41
    Will be purchasing a plasma soon with component inputs, alas my Panasonic DMRE-30 doesn't have component, so have a choice of either buying a standalone dvd player the Pioneer 575 with component or replacing the dvd recorder with a DMRE-55 component (thus saving space and connections)
    I know the DMRE-55 can output PAL progressive but grateful to know if it can output NTSC Progressive! Thanks.
  2. Delh68
    Delh68
    Dec 13, 2002
    1,045
    48
    +53
    I can confirm that my Panasonic E55 outputs both NTSC Progresssive Scan & Pal - I assume u will be buying a multi-region, or buying an upgrade remote??
    Delh68
  3. fuji
    fuji
    Jun 10, 2004
    41
    Thanks for the confirmation on progressive, yes will be def. buying a multi region which my old panny recorder sadly is not.
