Adam cornwall
Hi, I'm new to this forum having just set up a home cinema on a budget.
I decided upon a used Panasonic 530 as it had good reviews (the Samsung stuff seemed to be having reported issues) and I was looking for a Bluray player with built in freeview and smart hub.
The only issue is that the apps on the smart hub seem very limited, BBC iPlayer is there but no sign of 4OD or the ITV hub... does anyone know if it is possible to get these on this device?
regards
Adam
regards
Adam
