panasonic-dmr-pwt520eb set up help
moon
I posted this on another thread by mistake I think this is the correct thread.
Can anyone help please help me to set up and get the best sound from my blu-ray player panasonic-dmr-pwt520eb connected to Samsung ps64e8000 TV via hdmi and to Yamaha RX-A1010 AV receiver via coax/opt
I am getting very confused with the set up I do not know what settings to try and get the best out of blu-ray player so that the av receiver outputs the best sound as I don’t know the deference between bitstreem pcm ect. and have no idea what settings to put in the panasonic-dmr-pwt520eb
any advice would be helpfull
davepuma
The best settings will be achieved by connecting the bluray player to the AV Receiver via HDMI, then running a further HDMI cable from the AV Receiver to the TV to carry the picture.
Then set the bluray player to bitstream and turn secondary audio off/bd mix options off.
You need to use HDMI to access the latest HD audio formats e.g. DTS HD Master Audio and Dolby True HD.
http://www.avforums.com/forums/av-a...06-attempt-explain-high-definition-audio.html
If you have any questions on setting up the AV Receiver, there is an owners thread here:
http://www.avforums.com/forums/av-a...rx-a1010-rx-a2010-rx-a3010-owners-thread.html
moon
You make it sound so simply and you are right it works great,
you have helped me before on this forum with another problem I had
and I really appreciate your simple and helpful advice,
Thank You
