Panasonic DMR-HS2 Recorder - Region 1 Discs???
Discussion in 'Blu-ray & DVD Players & Recorders' started by norderney, Jan 14, 2003.
  1. norderney
    norderney
    Jan 27, 2002
    318
    Southampton
    +16
    I was wondering if I need to do anything to my Panasonic DMR-HS2 to make it play Region 1 discs?
    I have got a Multi Region machine but do I need to enter any codes to make it play R1 discs?
    Any advice would be most appreciated.
    Andrew Smith
  2. mjn
    mjn
    May 24, 2001
    17,614
    Herts, England
    +4,536
    try asking where you purchased the unit from, as you say it was bought MR
  3. wellsi
    wellsi
    Mar 28, 2002
    494
    London, UK
    +29
    I guessing your problem is more to do with the play back of NTSC, as opposed to it being a region 1 disc if you have a MR machine.
    In the HS2 setup settings, the "NTSC playback output" option can be set to "NTSC" or "PAL60", which you should change depending on your TV;
    My Philips widescreen cannot handle PAL60, but handles an NTSC signal perfectly, so I have the playback setting set to NTSC when playing NTSC discs.
    Hope this helps,
  4. norderney
    norderney
    Jan 27, 2002
    318
    Southampton
    +16
    Can the Panasonic DMR-HS1 DVD Recorder handle RCE Region 1 coded discs?
    I understand that Warner and Colombia are now using RCE on all their Region 1 discs.
  5. akash
    akash
    Feb 15, 2002
    90
    London
    If it is multi region . it should be on auto detect.
    the ntsc/pal settings should not make a difference.
    my mates dmr-e30 does not require manual region inputting
