ramjam55
I've recently bought a DMR-HS2 and I'm hppy with it, however I'm having some issues with the RGB signal. I have my Sky box connected from the TV out (RGB) to the AV2 RGB in on the HS2 and then from the AV1 on the HS2 into my plasma. When I have the AV1 and AV2 set to RGB on the HS2 and the AV2 mode as decoder (it just gives a blank screen in any other mode). When the HS2 is in standby, SKY gives a RGB picture which is not to bad, but when I switch the HS2 on the Sky picture degrades and looks to be outputing in composite (flicker around the edges on menus). The menus on the HS2 are fine and so it's outputing RGB from the HS2 but not from Sky. Any ideas why this is happening ? Maybe a config issue ? I'm using good scart leads (QED and IXOS).
