Panasonic DMR EX97 refuses to power on from remote
Discussion in 'Blu-ray & DVD Players & Recorders' started by linuxrocks, Jan 16, 2018.
  1. linuxrocks
    linuxrocks
    Jan 16, 2018
    3
    4
    Black Country
    Has anybody experienced their DMR EX97 refusing to power on from the remote? Mine has done it a few times now. I can always switch it on by leaning on the main on/off switch on the machine. I've spoken to Panasonic about it and they said "it was probably trying to protect an internal component" and that I should return it for service. This sounds like garbage to me - I suspect it needs a firmware patch but none isn't available. It normally isn't a problem, but I suspect this is why I missed several programs that I was trying to record on timer yesterday.
  2. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,079
    +6,961
    Welcome to the forum.
    The most likely explanation is that the power switch button on the remote control is not reliably activating an output from the remote when the button is pushed.
    It is a relatively common button failure as users often tend to overpush the power switch because the machine does not respond immediately to a power on instruction.
    You can check to see if this is the problem by using a camera or phone camera ( anything which has an electronic viewfinder ). If you point the output of the remote at the camera lens and monitor the results on the viewfinder screen you should see the infra red LED pulsing every time a button is pressed.
    This problem will absolutely no bearing on failed timer recordings. The explanation for that will lie elsewhere.
    There are a number of channel changes and channel movements taking place just at the moment so the unit most probably requires a retune.
  3. linuxrocks
    linuxrocks
    Jan 16, 2018
    3
    4
    Black Country
    As far as I can tell, there is nothing wrong with the remote. When I press the power on button, the LED flashes on the machine, but it refuses to power on. If I power it on with the button on the machine, I can then power it off with the remote.
    I am very unimpressed with the Panasonic. My SONY RDR-HXD890 never missed a recording (the Panasonic does quite regularly) and would burn DVDs far quicker. Shame Panasonic are the only players in the market.
  4. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,079
    +6,961
    OK - When the LED flashes whilst you push the power on button, is anything shown on the (machine's) display for a few seconds?
    Missed recordings are usually due to EPG conflicts caused by tuning issues such as picking up channels from more than one transmitter.
    Remedies are to clear out the machine by doing a tuning scan with the aerial detached, then reattach and scan once more.
  5. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,079
    +6,961
    Transmissions and techniques have changed quite a bit since the days of the Sony '890
    The biggest change is that transmissions now include HD and that has brought a change in the way such recorders record.
    You may be finding the burning process slow because you are recording in DR mode... which is an 'unencoded' form of recording that will not go directly onto a disk without going through an encoding process which can only be done in real time.
    If you record in a another mode, say SP for example, you would then be able to high speed copy the recording to DVD as the encoding process is done at the time of recording.
  6. cantique
    cantique
    Feb 18, 2017
    5
    Durham
    I've also had this problem and certain that it's not the remote at fault. The only solution seems to be to power it off by holding down the on/off button on the machine and then switching it back on. Not much use if there's a recording underway.
    I did wonder whether it was related to the HDD being pretty full (23h remaining).
    Linuxrocks: did you find a solution?
  7. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,079
    +6,961
    No - it will not be that.
    This is a control failure and will almost certainly be due to data corruption reaching the processor. ( which is cleared by doing a reset as you describe. )
    The same thing is achieved via a power disconnection.
  8. linuxrocks
    linuxrocks
    Jan 16, 2018
    3
    4
    Black Country
    Not in any real sense. I'm convinced it is a fault in the controlling software and it needs an update, except there isn't one available, and I can't see Panasonic doing one. Anyway, my "solution" was to buy a PVR and record the programs on that as well as the DVD recorder. If the DVD recorder doesn't wake up, I can still watch the program on the PVR and if I want to burn it to DVD, do that via the PC.
    The DVD recorder refused to wake up twice last week, twice in three days. It really is a piss of sh*t.
  9. redsox9
    redsox9
    Sep 13, 2007
    3
    +4
    My Panasonic DMR-EX97 also occasionally will not power on from the remote but does not seem to miss timer recordings. I simply disconnect it from the mains and reconnect and the remote power on works again. Mine seems to only record in DR mode. Under the edit function, the recording can then be easily transformed to SP or LP for fast transfer to DVD. Is it capable of recording in SP or LP mode off Freeview? Even the LP gives a good screen render and two films can fit in one DVD. I love it -- the third and best Panasonic recorder I have owned over the years.
  10. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,079
    +6,961
    Yes.
    If doing a manual recording, use the 'Record Mode' button to change recording modes. (Just to the right of Record button on the remote).
    If doing a timer record, there will be a mode setting in the timer screen which you can change.
    Be aware that once you change it, all timer recordings you set thereafter will probably default to that new setting you have chosen - until you change it to something else.
  11. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,079
    +6,961
  12. Chris1980
    Chris1980
    May 15, 2018
    16
    3
    Wirral, Merseyside
    +3
    Does anyone have a similar issue with their DMR EX97 to me? I'm sure I have a fault with my recorder from time to time which stops the remote control unit responding!
    As everyone who owns one of these machines will probably know, around 3:00am, the machine uploads the programme guide for the next day and this is obviously shown by the word 'GUIDE' which appears in the front display.
    A little bit before this happens, you hear the cooling fan on the rear of the unit kick in and after about 10 minutes, it does the upload which lasts for approximately 30 minutes. Once the upload is complete, the word guide disappears from the display and the cooling fan should go off.
    BUT....... there seems to be an issue on mine regarding the cooling fan!
    I purchased my DMR-EX97 from Currys in January 2018 and have noticed that every few weeks, mine seems to upload the programme guide ok but the cooling fan on occasions will just permanently stay running! The last time it did it, I thought I'd ignore it and give the machine longer to see what happened (in the hope it would turn off by itself). However, even after 24 hours, the fan was still running!
    On these days when the fan doesn't turn off and I press the on/off button on the remote control, I can see a green flashing dot in the display obviously meaning that it has detected a button has been pressed but nothing actually happens! The only way I can get the machine to work again (when this happens) is by holding down the power button on the unit itself for a few seconds forcing it to 'shut down'. The fan then stops and I can operate the machine again then as normal.
    There are days when the fan switches off normally after the nightly programme guide upload and it can seem totally normal for a few weeks. Every few weeks though, the machine seems to act up by showing the fan staying on issue and not responding to the remote.
    I tried taking it back to Currys in March but unfortunately, they couldn't offer me a replacement unit as it was outside the 30 day return period. All they could offer me was a repair but I've just put up with the issue for now as I regularly use the machine and didn't really want to be without a recorder.
    I have even tried e-mailing Panasonic themselves to see what they could suggest and one of their technical support guys suggested to try turning off the auto updates and doing a factory reset as that would possibly fix the problem. Having tried what they recommended, the issue is STILL there every few weeks.
    Has anyone come across this issue before with any of their EX97 machines as I'm convinced mine must be faulty!
    It is kept on a table with plenty of air flow around the back and sides so I can't see it being an overheating issue.
    Would appreciate if anyone could shed any light on what is possibly wrong or if this is a well known issue on these?
    I'm thinking of maybe buying another eventually and selling my current one on eBay as I'm thinking something isn't quite 100% right with it and hasn't been from the day I bought it brand new!
    Thanks.
  13. redsox9
    redsox9
    Sep 13, 2007
    3
    +4
    Gavtech, do you know what time Panasonic usually broadcasts its firmware updates? I tried to update the firmware on my Panasonic DMR-EX97EB with the new version 1.04 but there was none being broadcast. I much prefer the air broadcast method rather than an Internet download.
  14. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,079
    +6,961
    I believe that the OTA download services have ceased now unfortunately.
    Story here.
    So I think you will have to follow the procedure as laid out here.
  15. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,079
    +6,961
    Before doing anything - update the software to Version 1:04 . There is a link to it in the post above yours.
  16. redsox9
    redsox9
    Sep 13, 2007
    3
    +4
  17. redsox9
    redsox9
    Sep 13, 2007
    3
    +4
    Thanks, I did not know the OTA download services had been stopped. The new firmware version says it improves "network service compatibility." Do you know what that terse phrase means?
  18. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,079
    +6,961
    Sorry - I don't know exactly... but Panasonic only ever issue updates to deal with problems that arise as a result of broadcast changes.
    There are now enough reports of the unit becoming unresponsive to the remote control to indicate that this has been a system failure... no doubt caused as a result of recent broadcast changes.
    Evidently those changes have been causing a corruption resulting in processor lockup which can only be reset by a mains disconnection.
    I suspect that this update will be to address that problem.... to make the unit compatible with the broadcast changes.
  19. Chris1980
    Chris1980
    May 15, 2018
    16
    3
    Wirral, Merseyside
    +3
    Thanks Gavtech.
    Will give this a try during the week sometime and see what happens.
    Maybe it is a software glitch with the old Firmware that is causing the fan to sometimes stay running.
  20. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,079
    +6,961
    If the processor gets a lockup occurring in any process then it is effectively disabled and cannot 'do' anything more.
    The act of overnight updating involves using the tuner and timer processor which is energy intensive and can result in the fan coming on.
    If the processor locks up during that process it cannot then turn the fan off - so if the first problem is solved, so the lockup does not occur, the second ( the fan) should be too.
  21. Chris1980
    Chris1980
    May 15, 2018
    16
    3
    Wirral, Merseyside
    +3
    Thanks Gavtech. Possibly this Firmware update will solve it!
    Will download it onto a USB stick over the weekend and install it. (I haven't updated the Firmware since I bought the machine and have just been using it as a Recorder/DVD player as it is). I think from what I remember seeing, I'm on Firmware version 1.00 still or whatever version was the default straight out of the box.
    The problem doesn't show up sometimes for a few weeks but I will definitely let you know in a few weeks time if it reoccurs or seems to be solved.
    Appreciate your help and thank you. :)
  22. Chris1980
    Chris1980
    May 15, 2018
    16
    3
    Wirral, Merseyside
    +3
    Well I've updated my machine on Saturday morning and was on Firmware version 1.03 at first. (I'm now on the most recent 1.04 version).
    Very easy to do following the instructions to download and save the update file to a USB pen.
    I'm HOPING this new version fixes the problem! Other than the slight issue I have with the fan from time to time, the DMR-EX97 is a brilliant piece of kit!
    Will let you all know in a few weeks what happens. :)
  23. Markrecorder
    Markrecorder
    May 24, 2018
    4
    London
    I've had this issue once or twice about a year ago (bought the Panasonic about 2 years ago) but in the past week it's now happened 3 times. Can't get it to turn on with the remote but can see the little yellow flash on the display telling me it's getting a signal from the remote, and when I listen to the machine, it's humming away to itself (the fan, I now know).
    I've been switching it on and off at the mains to fix it and that's worked. I'll give the update a try. Would be really interested to hear how others get on with this too.
    Generally find it a good machine especially being able to record 2 different programmes at the same time and watch a third or a recording or a DVD.
  24. Chris1980
    Chris1980
    May 15, 2018
    16
    3
    Wirral, Merseyside
    +3
    What Firmware version where you previously on?
    Mine was 1.03, I've now updated to 1.04 (as per a recommendation by someone further up the thread).
    Someone has said this would possibly address problems like this and hopefully improve stability.
    The 1.04 Firmware version was made available literally I think only a week or so ago and yes, it does make you wonder why it has taken Panasonic all this time to realise there are issues and release a patch! To my knowledge, the DMR-EX97 model has been around now for quite a few years!
    I'd also been trying several things such as switching it off at the mains and have even done full factory resets but the fan issue has always returned weeks later! (This was prior to me updating the Firmware).
    All I can say up to now is so far, so good but it is early days yet as I only installed the Firmware last weekend! With my recorder, it can often take a few weeks of it working normally before the issue will re-appear!
    On the whole, it does seem a good machine although I've not used mine to its full potential yet! For example, transferring anything to DVD and I've still yet to try the twin tuner recording feature!
    I'm glad to learn though that I'm not alone with the same problem and would love to hear back if this recent 1.04 update solves it for you!
    Please do keep us informed. :thumbsup:
  25. Markrecorder
    Markrecorder
    May 24, 2018
    4
    London
    Just to report in - I had the same experience this morning - constantly whirring fan and no response to the remote control.
    I switched it off and on again at the mains which sorted the immediate issue.
    I've just checked my firmware now and I'm on software version 1.00!
    So, I guess that might suggest my machine hasn't received any updates since I bought it - via broadcast signal.
    I'm going to follow the update process to go to 1.04 and see how that goes. Don't know if I'll get it done today but will update this forum on how it goes and if it fixes the problem.
    As the problem is now happening on a daily basis, I would hope I'll know by the next day whether it has worked or not.
    Thanks for all the useful info on here!
  26. Chris1980
    Chris1980
    May 15, 2018
    16
    3
    Wirral, Merseyside
    +3
    For the first time ever since updating my machine to Firmware 1.04, the fan has started to run this afternoon and now doesn't seem to be stopping today by itself!
    There is nothing shown in the display on the front so not as if the machine is busy doing anything behind the scenes! When I got up this morning, the fan was NOT running then!
    So it is looking like the recent 1.04 update hasn't solved anything!
    I honestly don't know what could be causing it as a few others in the forum have also mentioned this issue.
    I don't also know if there would be any point in buying another DMR-EX97 machine (thinking my current one is faulty) as I've got this feeling there is a good possibility exactly the same would happen again with another machine of the same make and model number.
  27. Markrecorder
    Markrecorder
    May 24, 2018
    4
    London
    Okay - updated my machine from v1.0 to v1.04 on Saturday.
    Pre-update, the fan would be going every morning (last 3 or 4 mornings) and the recorder would not respond to the remote.
    Since the update on Saturday evening the machine has been fine on the two mornings since - no fan and responds to remote - so seems to have done something.
    Of course, I'm not 100% confident the problem won't recur.
    @Chris1980 as it's so new, are you sure you couldn't get the retailer to exchange or refund on your machine? I'm sure the law may be on your side on this, as the machine could be said to be not fit for purpose and it's only a few months old.
    I wouldn't be happy giving it to them to repair. I think that would be months of pain until it came back - probably still broken.
    Mine's a couple of years old at least but it does at least trundle on doing the job and Like you say, there aren't many similar in the market.
    Just checked this I want to return my goods, what are my rights?
    Apparently you do have to give them the opportunity to repair it...
  28. Chris1980
    Chris1980
    May 15, 2018
    16
    3
    Wirral, Merseyside
    +3
  29. Chris1980
    Chris1980
    May 15, 2018
    16
    3
    Wirral, Merseyside
    +3
    @Markrecorder
    Did try to persuade Currys to give me an exchange back in March but being over the 30 day return period, only a repair could be offered.
    My machine has been better since the update when it has been uploading the programme guide in the early hours as that was when the fan and no response to the remote was mainly happening then. It has not done it then so far since.
    It just randomly starting running that other afternoon and the remote response 'locked up'. It had never happened mid afternoon before.
    All I can do I suppose is stick with it for now and see if it happens again. Maybe
    a further update will be released one day!
    I'm still not confident that even a replacement DMR-EX97 will be perfect!
    Please keep us updated as it would be interesting to know if your recorder ever does it again. Even if it ever happens one afternoon at random like mine did the other day!
  30. Chris1980
    Chris1980
    May 15, 2018
    16
    3
    Wirral, Merseyside
    +3
    Update for everyone to try and get us some help and hopefully....... a fix for these issues!
    I've e-mailed Panasonic tonight with the following to make them aware that there is a widely well known fault with these recorders.
    I previously messaged for support a month or so ago about a small problem concerning a slight flaw with the Panasonic DMR-EX97 Freeview Recorder/DVD player.
    The problem being now and again, it doesn't respond to the remote and the cooling fan stays permanently running. This results in having to do a force 'shut down' by holding down the power button on the top of the unit before the recorder is fully operational again.
    One of your Support Team suggested turning off the auto updates and doing a factory reset as this would possibly fix the problem but it still persists from time to time.
    It would appear this is a known issue with these recorders. (Please see the link below of a forum myself and many other owners of this have posted in. And I'm known as Chris1980 in that forum).
    Whilst my machine has gone a little bit better since the most recent firmware 1.04 update and I've yet to see the fault happening again some nights after 3:00am (as it would usually only happen after the programme guide had uploaded), there was an occasion the other afternoon when the fan randomly turned on, wouldn't go off on its own and it wouldn't respond to the remote.
    I was just wondering for myself and on behalf of the other owners in the above forum, if there was going to be any future Firmware updates planned that would address this issue?
    As you can see, I'm not the only person who owns one of these machines that this fault is happening with.
    Many thanks in advance for your help.
    Kind Regards,
    Chris.
    Let's hope they release another update on receipt of this to try and correct our issue!
    Got to be worth a try contacting them! Right? :)
