A friend has this problem, and I offered to ask here. I told them you were a reliable bunch – I hope you won’t let me down!!
The above is not showing content on the guide. After some reading here, have done the following:
· Unplugged for 24 hrs
· Pressed up/down channel buttons for a reset
· Menu, auto setup restart
All to no avail. Date & time is showing properly.
After the last of the above, the message “no stations found. Check aerial” came up. However the aerial is routed via the DMR to the TV (also a Panasonic) on which the guide showing properly and has good reception (they are right underneath Caradon Hill transmitter!).
I’ve seen this post: Panasonic DMR-EZ45VEBS (and DMR-EX95) no digital channels found | AVForums which appears to cover this issue. Don’t have the capability for this intrusive “heart surgery” so sincerely hope there might be another option (buy a new one?!).
Any suggestions?
pb
Any suggestions?
pb
