panasonic dmr-ex87 connection problems
Discussion in 'Blu-ray & DVD Players & Recorders' started by SPARTANS, Sep 17, 2007.
  1. SPARTANS
    SPARTANS
    Anybody help please as i'm having a few problems with the connections.
    I have a 42pz700 panasonic tv,dvd recorder and sd sky box.
    I've connected teh cables up as follows
    sky - 1 scart into tv and the other into dvd.
    dvd - hmdi cable into tv,1 scart into tv and the other into sky box.
    i can watch sky on tv but not through dvd recorder,get sound but no picture.
    Anybody got any ideas why please
  2. MuksC
    MuksC
    Aug 18, 2007
    885
    43
    +133
    I have the EX77 and am only connect via scart to the tv and Sky box, no HD tv so no HDMI leads required.
    so you've pressed the Input Select button to get to the Sky channel, but you can only hear it?
    unless there's something wrong with the cable connnecting the Sky box to the dvd recorder, i can't think what it could be.
  3. Adrian_F
    Adrian_F
    Jun 29, 2007
    1,426
    83
    +293
    Have you configured AV2 on the EX87 to accept RGB/Video ? If not then please do so. This setting can be found in Functions-To Others-Setup-Connection.
  4. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,156
    +7,097
    You will also have to ensure that it is the TV scart from sky that is feeding the DVDR as this is the only socket that outputs RGB.
    It sounds like you are probably configured this way in any case.
    I believe your problem has something to do with using the AV/TV button on the sky remote [ If that is what it is called - I've never seen a sky remote ... Sky - Ptooey]
    Under certain conditions, when this button is pressed, it removes the RGB output - which would account for you having sound only.
  5. SPARTANS
    SPARTANS
    many thnaks for the replies fellas,its working now okay,had the scarts in the sky box the wrong way round ,switched them over and its okay now.
    cheers
  6. Adrian_F
    Adrian_F
    Jun 29, 2007
    1,426
    83
    +293
    Glad that things are now working for you.
    However if you intend to use Autoview on the Digibox then be aware that when it wakes up with Autoview the output is only composite and you will have the same problem unless you configure AV2 to accept RGB/Video.
