Panasonic DMR-EX83 DVD recorder USB problem
Dally
does anyone know how i can get this dvd recorder to play files (avi) from a usb memory stick?
it is not being recognised when i insert it.
basically i've got a movie from my iphone that i want to transfer to its hd.
the file is a mov so i have converted it to avi but nothing happens
Gavtech
Administrator
It is not clear:
Is it the memory stick that is not being recognised...or the file?
Gavtech
Administrator
the memory stick
Check the formatting of the stick. It must be a FAT 16 or FAT32 partition.
These are all the requirements:
USB memories which are defined as USB mass storage class, and digital cameras that use PTP protocol:
USB memories that support USB 1.0/1.1 and USB 2.0 Full Speed/High Speed.
USB memories of up to 128 GB can be used.
USB memories that support bulk only transfer.CBI (Control/Bulk/Interrupt) is not supported.
Digital Cameras which require additional programme installation when connected to a PC are not supported.
MTP (Media Transport Protocol) device is not supported.
A multi-port USB card reader is not supported.
Format
FAT16 and FAT32 file systems are supported.
UDF/NTFS/exFAT file system is not supported.
Depending on the sector size, some files may not work.
Only the first partition on USB memories with multi-partition is supported.​
Dally
Thanks - sorted now.
It had multiple partitions :(
and I also found out that the video has to be DivX encoded
It plays fine now but the recorder will not copy this file over to either the HDD or to a DVD
