Panasonic DMR-EX78 problem
SD Viewer
My Panasonic DMR-EX78 has now started to output recorded programs as 4:3 via HDMI (ie. the 16:9 picture has bars at the sides and above/below) , and the only way to get a watchable picture is to use scart and adjust the TV to "Zoom" ratio. When watching live TV using the Panasonic's tuner it outputs correctly via HDMI. I have checked that the aspect ratio is set to 16:9 (confirmed by the way live TV is OK) and have tried rebooting it by switching it off and on again at the mains. I have also swapped the HDMI input cables round at the TV end to check it isn't one of the HDMI inputs on the TV that is playing up. Before I make a warranty claim, please could you suggest if there is anything else I can try.
Gavtech
Administrator
Check the aspect setting for HDMI as described on page 75.
This describes how 4:3 aspect material is handled when delivered by HDMI.
[ Incidentally - The results you get will depend on which channel you recorded. Some of the 'lesser' channels deliver 'sub size' pictures. ]
SD Viewer
Thanks for the quick reply. I have checked the page you mention and this confirms the unit is set correctly. I don't understand why it thinks 16:9 recordings are 4:3. It has only just started to do this and I hadn't changed any settings anywhere.
The recordings are from the main four channels and prime time shows. Also I had recorded some of the same shows on my Topfield 5810 and these work fine, so the Panasonic appears to have developed a fault. I just hope the shop recognise there is a problem...
Gavtech
Administrator
Is it ALL recordings? and do you know for sure that they are 16:9 ?
Broadcast material comes in all shapes and sizes depending on the source channel and material.
Have you tried that setting the opposite way? - because it is kind of counter-intuitive - ie. If the source material happens to be 4:3 and you want it to fill your screen you have make that setting 4:3 , not 16:9.
It 's also worth bearing in mind that your TV may be responsible and maybe needs resetting.
Adrian_F
I occasionally get this problem with my EX77 (although I view via scart), the recorder just sticks in 4:3 now and then. I find that by switching off at the mains for 5-10 mins the machine will correct itself.
Podcast: CES '22 TV Announcement Round-up, Plus, Most Anticipated Movies of 2022 and More...
