Panasonic DMR-EX75 Distorted sound freeview
Discussion in 'Blu-ray & DVD Players & Recorders' started by bnc, Jan 20, 2008.
  1. bnc
    bnc
    May 12, 2007
    27
    I have noticed a slight problem with my DMR-EX75 when I record using the inbuilt freeview the sound is very slightly distorted.
    Is there any way of adjusting the level of this in a service menu.
    Thanks.
  2. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,132
    +7,052
    No - there is no way to adjust the level.
    It is much more likely that the problem lies elswhere ... or was just a peculiarity of the source you happened to record.
    You need to be able to do this repeatedly to be able to demonstrate such a fault - which given the nature of the signal handling is extremely unlikely to be caused by the recording system of the EX75.
    Are you playing back sound solely through the TV?
  3. bnc
    bnc
    May 12, 2007
    27
    Tried both using the TV and using the optical out to my amp.
    Only seems to happen with the freeview tuner.
