Panasonic DMR-ES10 & freeview box
Discussion in 'Blu-ray & DVD Players & Recorders' started by Ace T, Aug 18, 2005.
  1. Ace T
    Ace T
    Sep 17, 2003
    349
    Watford
    +3
    If I bought this DVD player and connected it to an external freeview box then would I be able to record from freeview ok?
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,720
    Warwick
    +2,599
    Yes - although you'll get better performance and features by purchasing the DMR-ES20D version which has in integrated Freeview tuner.
  3. etaf
    etaf
    Dec 1, 2004
    1,013
    +63
    i had a es10 for a few days and used a fvrt200 freeview to connect to it and record but, I replaced it with the ES20 more flexibity and it uses video+ for freeview - just does not enter the channel - so you put the video plus code in and then change channels. But with the guide the big advantage is I can just schedule a few programs on it. Not possible with a freeviewbox connected as I would eed to be around to change channels
