Panasonic DMR-ES10 DVD's playback on PC
Discussion in 'Blu-ray & DVD Players & Recorders' started by jm1, Aug 31, 2005.
  1. jm1
    jm1
    Feb 9, 2003
    371
    28
    +90
    I have just copied some vhs tapes to three dvd's with a Panasonic DMR-ES10, the dvd's play and look great on tv, but when played on my PC, you can see a line right across the bottom of the picture, it's like a thin mirror effect, all three dvd's are the same, I'm using PowerDVD, and BSplayer Pro to play them.
    Has anyone experienced this or any info on this problem?
    jm1
  2. Alan_Semple
    Alan_Semple
    Jun 25, 2005
    3
    Hi there
    On a PC monitor screen you do not have the same amount of overscan that you would normally have on a TV.
    What you are probably seeing is the VCR head "switching point".
    Check this out:
    http://www.ee.washington.edu/conselec/CE/kuhn/vcr/vcr.htm
    Alan
  3. jm1
    jm1
    Feb 9, 2003
    371
    28
    +90
    Thanks for your reply Alan, it explains the problem alright, it's still a very annoying problem, I don't recall anyone else asking about it, it can't be just me :rolleyes:
    jm1.
