hififan1950
Hi All,
Ever since I purchased my Panasonic DMR-ES10 DVD recorder second hand (it was stated as as new ), the clock/counter/fluro display is very dim, EVEN with the setting on high.
I have read of this problem on various sites/forums.
Doeas anyone know a cure for this seemingly 'stock' problem with the unit ?
IF it is just a faulty display, does anyone know the make and part number ?
I do not have a service manual to fin the latter info, and Panaonic state they will not supply me with a new display as I am not a dealer (usual Panasonic !!!).
Please help if you can please as there is a lot of these recorders out there with the same problem it seem !!!???
Thanks------Chris
Thanks------Chris
