Panasonic DMR ES10 - can it be modified for region 1
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by pwood, Jul 14, 2005.
  1. pwood
    pwood
    Dec 6, 2003
    2,569
    Central Scotland
    +163
    I'm getting this player as part of a package with my 42"PV500 plasma and was wondering how this machine can be set to play region1 DVD's.
  2. Roohster
    Roohster
    Jul 1, 2004
    3,791
    4
    2
    Derbyshire
    +3,821
    It can be done, but only by a dealer, or someone with access to a particular type of remote. You can hire these remotes for a day or so.
    Alternatively, ask the dealer where you're getting your PV500 from if they can sort it out - that's what I did.
  3. Steve1971
    Steve1971
    May 29, 2004
    76
    Halifax
  4. pwood
    pwood
    Dec 6, 2003
    2,569
    Central Scotland
    +163
    Cheers. I kinda though there was more to it than a standard handset hack. I will ask the dealer. :smashin:
  5. Justin@UH
    Justin@UH
    Feb 21, 2002
    2,192
    63
    Location location location
    +93
    Amost all dealers can supply this pre-modded for multiregion. A google search would give you info on dealers and stuff that can supply it pre-modded, or can mod it for you ;)
  6. oh aye
    oh aye
    My package arrived 37pv500cab and dmr es10 and found they had region chipped it anyway i hadn't asked them. I bought it at soundandvisiononline.com (sorry not sure how to put links in). The dealer will probably region chip it for you if you ask.
  7. Justin@UH
    Justin@UH
    Feb 21, 2002
    2,192
    63
    +93
    Yup S&V usually offer most of their gear pre-modded (as do many others) :)
  8. rutteger
    rutteger
    Apr 29, 2004
    452
    +7
    Anybody know if the IR codes to 'hack' the DMR-ES10 are available for use with a Pronto?
    Or are the one-time service remotes these retailers are selling for multi region upgrades super special ones?
  9. Justin@UH
    Justin@UH
    Feb 21, 2002
    2,192
    63
    +93
    This has been asked before in other threads, and there is no way to do it without a service remote from a dealer or to buy a unit pre-modded.
  10. rutteger
    rutteger
    Apr 29, 2004
    452
    +7
    Fair enough, thanks for your reply.
  11. e_python
    e_python
    My ES10 was delivered from John Lewis and it is not Multi Region. What is the cheapest option that I have available to make it multi region. :lease:
    Hiring the remote sounds like a good idea. More info please.
  12. Justin@UH
    Justin@UH
    Feb 21, 2002
    2,192
    63
    +93
    You`ll find more info regarding modifications for panasonic models by either a google search, clicking the banner at the bottom of the page, or a quick search of the forums.
  13. e_python
    e_python
    Most of these remotes seem to be single use.
    Is it because sellers are being greedy and they do not want people to flog it on ebay after they have used it. ie they do not want a second hand market for these things.
  14. Justin@UH
    Justin@UH
    Feb 21, 2002
    2,192
    63
    +93
    ? You are paying for a service, NOt for a product. You have the DIY option rather then sending / taking in your machine for modification to the dealer.
    For such a new model there is no reason not to buy it pre-modified in the first place.
