Panasonic DMR-EH60 is region 2 i put a region 1 disc and it says unsupported tv syste
Discussion in 'Blu-ray & DVD Players & Recorders' started by the blue angel, Aug 28, 2005.
  1. the blue angel
    the blue angel
    May 20, 2005
    119
    16
    unsupported tv system i went into the players menue and changed to ntsc
    and it played region 1 disc is this correct or will it do any damage to machine or tele
  2. the blue angel
    the blue angel
    May 20, 2005
    119
    16
    is this correct as it playes region 1 no problems if i do this
  3. HMHB
    HMHB
    Nov 11, 2001
    26,715
    Nottinghamshire
    +5,482
    Threads merged into one.
  4. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,424
    Somewhere in South Yorkshire
    +5,823
    Won't do any harm.
    Not all R1 discs are actually R1 only. Some odd ones are dual coded for the Japanese market which is R2, NTSC. Some are region free.
  5. the blue angel
    the blue angel
    May 20, 2005
    119
    16
    if you bought a region 2 dvd panasonic dmreh60 dvd recorder would you send back and get a multiregion one
  6. LV426
    LV426
    Jul 14, 2000
    13,424
    +5,823
    Unless you ordered a multiregion version, this isn't grounds for a refund or replacement.
    The answer is that, really, you should always have a MR machine. You may be able to get yours modified (if it needs it). Try http://www.dvdchips.co.uk/
