Panasonic DMR-EH50 - turning itself on
Discussion in 'Blu-ray & DVD Players & Recorders' started by MiniRoll, May 19, 2005.
  1. MiniRoll
    MiniRoll
    Apr 27, 2005
    80
    A week or so ago I was watching something on Sky. My Panny EH50 was in Standby with Ext Link on. Then the EH50 suddenly turned itself on and after about 1-2 minutes turned itself off again.
    Also, a coulpe of times I've left it in Standby with Ext Link on and found that it has turned itself on (I did doubt myself the first time it happened).
    It definitely happened again yesterday. I got in from work, had a look at the EH50 and it was still in standby with Ext Link on. I got changed and made some dinner and when I next looked, the EH50 was on and Ext Link was no longer lit.
    Has anyone experienced anything similar. Twice when I have noticed this happening, the EH50 has been in direct (although very weak) early evening sunlight. Could this be triggering the problems? (although none of my other equipment has ever been effected)
    I would like to think that I could go on holiday with Ext Link set and the EH50 would record everything set in the Sky Planner. So far, I do not feel confident that this would work.
  2. docb
    docb
    Nov 22, 2004
    240
    Have a search for "ext link" on this forum, it has happened quite often to people.
  3. MiniRoll
    MiniRoll
    Apr 27, 2005
    80
    docb
    I know there has been a lot of talk of ext link and I have checked into this. However, the problem I have raised above has not, as far as I can tell, been covered.
    So, any help, or similiar experiences greatfully received :D
  4. MiniRoll
    MiniRoll
    Apr 27, 2005
    80
    It definitely is not the sun that's cauing it. It happened again tonight at about 20:25 :(
  5. Gary D
    Gary D
    Jan 9, 2002
    7,770
    +826
    in short take it back its cream crackered. the EH50 has "issues" there is nothing YOU can do about its a manufacturing fault.
    gary
  6. nigelmurray
    nigelmurray
    I have the dmr eh52 which is exactly the same as the dmr eh50.A lot have people had the same problem that you are describing but this was solved by the new firmware version 303 which is on the panasonic website.
  7. Gary D
    Gary D
    Jan 9, 2002
    7,770
    +826
    can you provide a link?
    Gary
  8. nigelmurray
    nigelmurray
  9. MiniRoll
    MiniRoll
    Apr 27, 2005
    80
    I'm a bit worried about running a firmware upgrade - I assume it would invalidate my warranty?
  10. Gary D
    Gary D
    Jan 9, 2002
    7,770
    +826
    i'd worry about that firmware its GERMAN!! if it was me i wouldn't do it without Panasonic's say so or unless a loads of members had already done it.
    Gary
  11. MiniRoll
    MiniRoll
    Apr 27, 2005
    80
    Is there a way to tell what firmware version I'm currently using?
  12. MiniRoll
    MiniRoll
    Apr 27, 2005
    80
    Just had a thought - could my problems be caused by having a cheap SCART cable connecting my EH50 to my Sky box?
    Anyway, I have changed the cable for a better quality one (QED Squart). Fingers crossed!
  13. jeff1975
    jeff1975
    the dvr will record automaticlly if the dvr is on ext link and the sky channel is set on autoview
  14. balb0wa
    balb0wa
    May 23, 2005
    306
    Chesterfield,Derbyshire
    +10
    Hello,
    Well ive just used the german firmware , and its updated ok, all menus etc are in english still !
    just burnt it to a cd, inserted it, and it said updating etc on the display, was dead easy.
    will see if it solves the ext link problem
  15. MiniRoll
    MiniRoll
    Apr 27, 2005
    80
    A quick update.....
    I tried a higher quality scart with no joy. Still turning itself on. In fact it did this one when it was recording and therefore stopped recording half way through!
    Anyway, I've spoken to Panasonic and they think it's a problem with the Sky box passing a signal to the EH50. I said I thought it unlikely that a signal could be passed from the Sky box that would actually turn the EH50 on.
    So, for the next test, I've removed every connection from the EH50 (except the power). If it turns itself on now, I'll know it's the EH50 with the problem.
  16. MiniRoll
    MiniRoll
    Apr 27, 2005
    80
    Sorry me again.....
    Well, it did not take long. The EH50 turned itself on within about an hour. Got on the phone to Panasonic UK who said return to the dealer.
    Got in contact with Digital Point and they said to send it back and they will replace 'if they can find a fault'. They will not pay my postage irrespective of fault!
    I'm sending it to them using initial city link so they should get it tomorrow.
    I'd be interested to hear if anyone else has this problem just in case Digital Point say there's nothing wrong :lease:
  17. balb0wa
    balb0wa
    May 23, 2005
    306
    +10
    i got mine from digital point, im testing the new german firmware now, will let you know how i get on.
    I cant see digital point finding the fault though.
  18. Gary D
    Gary D
    Jan 9, 2002
    7,770
    +826
    When had the fault i videoed it with my phone!!! so they couldn't argue about it!! just a thought.
    Gary
  19. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,179
    London
    +399
    Scart cable and Pin 8 sounds like the root cause of this :)
  20. Gary D
    Gary D
    Jan 9, 2002
    7,770
    +826
    Ekko, the root cause of this is Panasonics faulty firmware. not the scart lead, as the firmware will be further down the chain than the scart lead then snipping the wire wont help. mine did it plugged in on the kitchen table with no leads connected to it.
    Gary
  21. Daftboy
    Daftboy
    Jan 8, 2004
    505
    +12
    Do these units have the EPG function like the european models?
  22. dicky
    dicky
    Apr 8, 2004
    165
    Cambs
    No
  23. Daftboy
    Daftboy
    Jan 8, 2004
    505
    +12
    Oh right okay then, only a thought as the european models have it on and it could have been a grey import. Sorry for asking.
  24. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,179
    London
    +399
    Nothing plugged into it ? Sounds like something else then. But if you did have it connected via scart, then I would put my money on Pin 8 being the problem That would be carrying the signal to trigger the Ext link.
  25. Daftboy
    Daftboy
    Jan 8, 2004
    505
    +12
    Looking at this thread, http://www.avforums.com/forums/showthread.php?t=212487 , maybe they have put the wrong firmware on as GaryD suggested.
    After 2 minutes in Standby, does the unit turn on before shutting down?
    This is why I have asked about the EPG, as units with this function on, power on (But show as standby) to search for the host channel and the listings. If they cannot find the channels, they then enter standby again and repeat this process I think about every hour or 2.
  26. dicky
    dicky
    Apr 8, 2004
    165
    Cambs
    No need to apologise, there was no more that I could put in my
    answer, I suppose, No it doesn't :D
  27. Gary D
    Gary D
    Jan 9, 2002
    7,770
    +826
    As i said ekko its the firmware. however, getting panasonic to admit it is impossible. when i phoned them the girl on the phone took a nano second to tell me that there are no problems with thier recorders, shwe didn't check or anything. in fact she mentioned it before i'd even finished the question. ha ha so i got an E85 instead :D
    gary
  28. docb
    docb
    Nov 22, 2004
    240
    I also have this problem and contacted AV sales about returning the unit.
    They have been in touch with Pana UK and they are sending me a disc with a firmware update on.
    Dont know if this is available generally, but sounds like an admission to me!!
    Will let you know if it works.
    Doc
  29. MiniRoll
    MiniRoll
    Apr 27, 2005
    80
    Doc
    Thanks for the info - this is very interesting. Do you know anything about the firmware update (version number etc?).
    I sent my EH50 back to Digital Point and they should have got it yesterday. I've not heard anything yet and have just sent them an email asking for an update.
  30. docb
    docb
    Nov 22, 2004
    240
    Miniroll
    not sure what version it is, i have been promised the disk by wednesday next week direct from panasonic.
    I will post when i get it.
    Doc
