Panasonic DMR EH50 HDD PROBLEM
D
dave rave
I have a panasonic DMR EH50 which i have a problem with,when i power up
the display reads hello for a few secs then bye,then hello again followed by
"hdd test av1" and then does not go any futher,does this mean that the hard
disk has failed,or has data needed on the hard disk been corrupted so the
panasonic cannot boot up,if i buy another hard disk of the same make and
spec would the panasonic then work correctly???? :)
aekostas
Talk to Panasonic Customer Services; they will advise you. They respond to email.
Good luck!
p.s.: If you can post findings, it will be much appreciated, TIA.
