Panasonic DMR-EH50 DMR-ES10 DMR-ES30V Updated Firmware
Discussion in 'Blu-ray & DVD Players & Recorders' started by cheekymonkey, Aug 28, 2005.
  1. cheekymonkey
    cheekymonkey
    Further to the post around firmware issues with EXT LINK on some Pannasonic DVD recorders
    (see http://www.avforums.com/forums/showthread.php?t=197655&goto=newpost)
    I had the similar problems with my EH50 and the update on rapidshare.de gave me the "UNSUPPORT" error which led me to believe this was not a newer version than my existing firmware?
    Anyway, I emailed [email protected] and got an almost instant response from a [email protected]
    who sent me a disc out the next day which was a "SVCD UPDATE DISC" for the DMR-ES10, DMR-ES30V and DMR-EH50 along with instructions.
    - Insert the disc into the player
    - The unit will momentarily switch itself off (showing BYE) and then on again.
    - The machine then starts to upgrade the software with the display showing the various section codes that are being checked.
    - After the machine has finished it will eject the disc and the display will show: -
    DRIVE>>>>UPD OK>>>>MAIN>>>>UPD OK
    - Remove the disc and power off the unit and once powered down remove the plug from the electrical socket and reconnect.
    the file date is 20/05/05 and is named PANA_DVD.FRM
    the link to this on rapidshare.de is
    http://rapidshare.de/files/4474584/PANA_DVD.FRM.html
    (I tried zipping the file but it remained virtually unchanged in size @ 15.2MB)
  2. jaytech
    jaytech
    May 25, 2009
    2
    3
  3. sidefall
    sidefall
    Aug 25, 2004
    54
    That's an interesting site, but it is American. I'd be very suspicious of trying any of that firmware on a UK machine.
  4. jaytech
    jaytech
    May 25, 2009
    2
    3
    Arhh, I didn't notice it was American. I tried to install the disc but it read "Unsupported".
    I know this means that the update is allready installed.
    I'll keep looking.
