Panasonic DMR-E85H
Discussion in 'Blu-ray & DVD Players & Recorders' started by paul1966, Dec 11, 2004.
  1. paul1966
    paul1966
    Nov 22, 2004
    68
    9
    Brighton
    About to buy my DVD/HDD today and I have decided on the Panasonic, good news is Richer Sounds are now doing them for £450 - BUT will price match any multi region player on the net as long as they are in stock.
    I was very impressed now about to search the web for prices and will put up what I find in an hour or so.
    I hope I am making the right decision :lease: :thumbsup: :clap: ..... so many diffrerent views in mags and this forum but this one seems the pick of the bunch - just.
    Would be grateful for any further thoughts, thanks.
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    I've used RS lots of times, and I'm not convinced that the stuff I've bought was manufacturer's "top grade" stuff. They also have a lot of models which are not quite the latest model. Having said that, I've had some very good deals from RS too.
    However, I must say that despite the price match offers, if a saw something I wanted elsewhere, I would probably go elsewhere. Look at Pricerunner for the best prices on the E85.
  3. paul1966
    paul1966
    Nov 22, 2004
    68
    9
    Brighton
    Thanks Nick
    I have done a pretty thorough search now and multi region is £399 including delivery at prcdirect and electro saver at £408 including delivery.
    The reason I was going to RS was its a ile away and if there is a problem I can take it back easy for the same price as on line. Personally not had any probs with products bought at RS. Thanks again for your thoughts.
  4. HMHB
    HMHB
    Nov 11, 2001
    25,555
    Nottinghamshire
    +3,884
    I got mine milti region from RS a couple of months ago for £399 on-line
  5. paul1966
    paul1966
    Nov 22, 2004
    68
    9
    Brighton
    Hi John
    Thanks for the info are you happy with it?
  6. HMHB
    HMHB
    Nov 11, 2001
    25,555
    Nottinghamshire
    +3,884
    Yes, very happy mate. I have Sky+ as well so mainly used it for converting VHS tapes and archiving stuff from the Sky+ hard disk so far. I like it so much that I bought an E55 for the bedroom so that I can swap RAM discs between the 2 :)
  7. MikeNolan
    MikeNolan
    Nov 28, 2004
    540
    Hereford
    Paul
    I agree with your comments about the easiness of returning faulty goods. However, you may wish to check out MultiRegionMagic in Peterborough. They advertise a lot in DVD mags and are currently doing the E85 for £399. They specialise in multi-region machines. I know their Panasonic machines also handle RCE encoded discs-not sure if RS do, and they also do auto region selection - ie you do not have to enter a code via the rem control. Not sure if this is across the Panasonic range or not.
    I had virtually decided to buy an E85 next week, but various comments about discs locking up as indicated on this forum leave me a little concerned.
    Hope this helps.
    Mike
  8. paul1966
    paul1966
    Nov 22, 2004
    68
    9
    Brighton
    Thanks off to buy it now for £399!
  9. paul1966
    paul1966
    Nov 22, 2004
    68
    9
    Brighton
    Thanks Mike
    It seems all the main machines, Panasonic, Toshiba and Pioneer have limitations or problems, so its a case of picking one and hoping for the best :thumbsup:
    As a matter of interest what else were you considering?
  10. MikeNolan
    MikeNolan
    Nov 28, 2004
    540
    Hereford
    Hi John
    Like Paul, I am thinking about an E85, but am a litlle concerned about disc lockups as discussed in the forum. How long have you had your machine? I too need a machine for the bedroom but have decided on the S27 which is available for around £65. In need the E85 to copy NTSC laser discs as well as VHS tapes.
  11. MikeNolan
    MikeNolan
    Nov 28, 2004
    540
    Hereford
    Paul
    The reason I was going for Panasonic was because I need a recorder that can copy some NTSC laser discs, and this seems the best bet. I have been told that Pioneer can do them, but the picture quaility is not so good.
    However, I guess your right about the problems. Maybe the bigger problem is explaining to the wife that the disc wont't replay or copy and I've just spent £400. She'll say "Never had that problem with the video"!!
    Give multiregion a call.
    Mike
  12. GASWATKINS
    GASWATKINS
    Mar 11, 2003
    245
    +10
    This seems to be the Panny i want to buy
    but with so many new models from Panasonic recently put out
    wont price drop a lot new year time on these old models ??
    plus its seems to be a Panny55 plus HD , yet a 40 gig hard disc should only add £50 max to price when i checked out computer shop of hard disc prices
    some margin added here i guess !!
    But before any body says i wont wait for ever
    but i do believe 2005 will see big drop on these recorders
  13. paul1966
    paul1966
    Nov 22, 2004
    68
    9
    Brighton
    Have now got my Panny E85 absolutely delighted with the machine - thanks everybody for your thoughts in helping me decide on which machine to get - although my girlfriend was not happy :mad: on Christmas day with me spending 2 hours redoing my network of tv, cable, reiver, video and dvd recorder etc etc :laugh: :thumbsup:
    If anybody has questions on this machine please let me know
    :smashin:
  14. Rasczak
    Rasczak
    Apr 3, 2002
    21,210
    Argyll
    +2,265
    Prices will continue to drop - but probably not that much more - they are heavily reduced already. The new models will probably start at a slightly higher price point before continue the general downward price trend. At least that is what has happened everytime so-far.
