Panasonic DMR-E85H Recording adds 1 minute...
Discussion in 'Blu-ray & DVD Players & Recorders' started by MTT1960, Oct 20, 2004.
  1. MTT1960
    MTT1960
    I have a e85H and noticed that when I record to the DVD-RAM using the 1hr XP format the recording goes to the hard disk. Similiar with the 2hr SP since it will be 121 minutes and will not fit.
    Then I tried a timed 1 minute recording and the record time went for 2 minutes!!
    It seems like someone made a big mistake when the firmware was written????
    My recorder is a USA unit and manufactured in March 2004. Panasonic has so far failed to respond to my complaint (its been over a month).
    Has anyone noticed this on their unit???
    Update: So far I have had three units with the most recent manufacturing date being April 2004...and all three recorders have this programming FLAW!!
    Still waiting for an explanation from PANASONIC!!!
    Thank you,
    Michael
  2. MTT1960
    MTT1960
    I don't understand why it takes so long for them to give me an answer???
    It's a simple problem that should be easily corrected with a firmware update!!!
    Hello PANASONIC????
    MIchael
