M
mcphert1
This is my first post, so I hope I have done it right. After about three years of owning the DMR-E85H hard drive dvd recorder, and lots of recording from the internal tuner to the hard drive, I have recently started experiencing a big deterioration in recording quality. In effect, the picture goes from good quality to being extremely grainy. The recording can commence ok but can switch to this poorer quality out of the blue during the recording. Currently about a third of programs will record normally, a third will be this poorer quality, and the other third will start out normal and then switch during the recording to this poorer quality.
I tried completely erasing the hard drive but this did not help. I might also say that I do not believe it is an aerial problem, as you can watch the internal tuner channels without this happening. I have to therefore deduce that it is a problem with the hard drive.
Have any others had this problem and are there any fixes?
Thanks for any help you might be able to give.
mcphert1
mcphert1
