Panasonic DMR-E85 picture stutter
Discussion in 'Blu-ray & DVD Players & Recorders' started by phoenix531, Jan 29, 2005.
  1. phoenix531
    phoenix531
    Nov 25, 2004
    13
    My Panny E85 DVD recorder plays DVD's perfectly and has been great so far (1 week) apart from when playing back recorded programs from the hard disk either digital or terrestrial. Quite frequently the picture stutters / freezes momentarily and the sound drops out at the same time.
    Can anyone help?
    TIA
  2. dangerouseddy
    dangerouseddy
    Dec 23, 2004
    36
    id get it replaced/repaired if its under warranty as it shouldnt stutter or freeze when playing back from hd if the source was ok (didnt stutter/freeze).
  3. Rasczak
    Rasczak
    Apr 3, 2002
    21,720
    Warwick
    +2,599
    Try formatting the HDD. If the problem still persists get the unit exchanged as it sounds like a faulty HDD - as on PCs new HDD are always prone to failure/problems.
  4. Tellyfiend
    Tellyfiend
    Jan 21, 2005
    225
    +13
    Phoenix, I had a very similar problem. I sent the machine back, but sods law, the supplier couldn't find anything wrong with it!!
    Still, they replaced it out of goodwill and my new one is working perfectly.
    Well done, [email protected] of Lincoln even if they did send the replacement to the wrong address!!!
