Panasonic DMR-E75V DVD-R / DVD-RAM & VHS Recorder. In UK yet?
Discussion in 'Blu-ray & DVD Players & Recorders' started by hearts, Aug 6, 2004.
  1. hearts
    hearts
    Feb 16, 2004
    74
    Is this DVD writer our in the UK yet? If so can anyone recommend it. I am looking for a DVD Writer that I will be able to use to transfer all my Videos to DVD. If this is not best can anyone recommend another.
  2. apreading
    apreading
    Jun 28, 2004
    283
    +15
  3. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    Lytham St Annes, where people are put out to grass
    Surely this is a one off event therefore why get the two combined. Why not buy a dvd recorder hook it up to your VCR then dump the VCr when you no longer need vhs
  4. hearts
    hearts
    Feb 16, 2004
    74
    Yes I know I could have just bought a DVD writer but I thought it might have been easier with this combined unit. I hoped someone who hasd one could tell me how easy it was to use and if it was a good buy. Also where I could buy it.
  5. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    Well I could tell you thats its easy without one. You connect them up via scart and press record on one with play on other. be a lot cheaper, and cheaper to replace of one bit (VHS or DVD burner) goes wrong!
  6. apreading
    apreading
    Jun 28, 2004
    283
    +15
    Like me, you may still want to use video though - in order to view other people's videos if they recorded something you want to watch or to avoid having to copy all the kids' videos to DVD or so that you can record home movies to give to relatives/friends etc.
    If I didnt want a hard disk I would go for the E75 in a shot. As it is I have an E85 and am thinking about adding the Panny DVD player/VCR (xxx31) for backing up DVDs, playing/copying VHS and because the E85 doesnt have a couple of features on DVD playback like zoom etc.
    Lets face it, DVD-R/RW/RAM recorders may be obsolete in a few years anyway as larger capacity media come on stream and also when you start getting freeview built in. So buying separate units (whilst I cant ultimately dispute your logic) doesnt really make alot of difference unless you are buying a cheap and unreliable make.
  7. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    I have a couple of midi stereos where either the CD or the tape is defunct!
    No longer believe in integrated products, epecially where the have tape drives! Now on third VCR in 10 years!!!!
