Panasonic DMR-E75?
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Anthall, Nov 2, 2004.
  1. Anthall
    Anthall
    Oct 27, 2004
    220
    Kettering
    +4
    Just a quick one. I see that this dvd recorder / video recorder is not multiregion! Does this mean there are no hacks either to open it up?
    Not a happy chappy.
    Thanks all!?!? :blush:
  2. MuffKing
    MuffKing
    It's a new machine mate. They often come out in time.
  3. Anthall
    Anthall
    Oct 27, 2004
    220
    Kettering
    +4
    cheers for the reply, but that didn't really answer my question.
  4. 69COU
    69COU
    Feb 8, 2004
    845
    +85
  5. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    www.dvdcodes.net appear to do a hack for this in the form of a pre-programmed remote which you use once and send back.
    I read somewhere that the Panasonic DMR-Exx range have a sequence of 43 commands to program them, which you can't do from an ordinary remote. Even if you could use your remote, program 1 command in wrong, and you have a piece of useless junk :suicide:
