Panasonic DMR E65 DVD Recorder CD playback
Discussion in 'Blu-ray & DVD Players & Recorders' started by STEVE LLOYD, Feb 1, 2005.
  1. STEVE LLOYD
    STEVE LLOYD
    sr
    I am having difficulty in playing CD's or DVD's that contain photos. The photos have been taken with a digital camera and then transfered to a disc via Ulead photo express software.
    When either disc is put in the recorder after a short while I get the following error messages, "Disc not recognised" or "Unsupported disc not compatible". I am not sure if it may be the file extension that may be causing the problem. Can anybody help :lease:
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,236
    Warwick
    +2,278
    You need to copy the files onto a DVD-RAM. The E65 will not read them from DVD-R/-RW or CD-R/-RW.
  3. STEVE LLOYD
    STEVE LLOYD
    Thanks for the advice on the dvd-rams. I will try this tomorrow. :thumbsup:
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,236
    Warwick
    +2,278
    Off the top of my head I can't remember what works and what doesn't for file structures - I think the machine is fairly tollerant but ensure all JPEGs are in a folder named "JPEG". If you run into trouble post here and we can work it through.
