Panasonic DMR-E55S
wsb_champ
I have the opportunity to buy a DMR-E55S from a American colleague (USA spec) for very little money. It is only 3 months old. I plan to use it here in the UK, other than the voltage issue - is there any other why is shouldn't be ok for use in UK ?
I noticed in the specs that the :
Video System for UK is PAL colour signal, 625 lines, 50 fields / NTSC colour signal 525 lines, 60 fields
where as the USA model is NTSC only.
I plan to connect to a Yamaha RXV450 and JVC 26" LLC TV.
any advise would be appreciated.
Rasczak
- No Scart connections
- Incompatible with PAL
- Incompatible tuner
...buy a UK model!
