Panasonic DMR-E55
Discussion in 'Blu-ray & DVD Players & Recorders' started by Welshman, Sep 16, 2004.
  1. Welshman
    Welshman
    can anyone tell me if this model has a DV input (ie to record directly off a camcorder or digital camera). Also i understand it only records to DVD RAM format so presumably dvds made will not play on most other normal dvd players. Can it also record to normal dvd-r, if not is there a similiar one on the market that does??
    Thanks for the help!
  2. Jerrysimon
    Jerrysimon
    Aug 26, 2004
    271
    +16
    DVi yep
    DVD RAM yep
    DVD-r yep
    That's it!
    Jerry
  3. kyle reece
    kyle reece
    it does not have digital video input!!sorry
    only the DMRE65 and DMRE95 have DVI
    but every thing else that jerrysimon says is correct
  4. Jerrysimon
    Jerrysimon
    Aug 26, 2004
    271
    +16
    Oops sorry Kyle is right NO DVi input :blush:
    I forgot I now have the Toshiba XS 32. This has all three pluss support for DVD-rw which is why I took back my E55 and then my E85.
    Regards
    Jerry
  5. Welshman
    Welshman
    Thanks guys, i wasnt sure if it had it. Ill probably go for the JVC DRM10 does any one have any experience of this?
  6. Rasczak
    Rasczak
    Apr 3, 2002
    21,700
    Warwick
    +2,578
    A better question might be if any has a good experience of this recorder. The DRM10 has had some faults/problems/issues. A earlier post suggested this might have be solved - but it doesn't alter the fact the recorder has no RGB input.
  7. Welshman
    Welshman
    I see, is there one you would recommend in that cas? im really looking for a RAM recorder that can also record to DVD-r or +r and has a DV camcorder/camera input
  8. Rasczak
    Rasczak
    Apr 3, 2002
    21,700
    Warwick
    +2,578
    The Panasonic E65 is a good choice: offers all the features of the Panasonic E55 plus DV input, PC/SD card slots and LPCM audio recording.
  9. Welshman
    Welshman
    Is there any other way to record the camcorder signal without a DV input?. If theres a way around i may go for the e55 as at £90 more the E65 and toshiba dr2 are a bit out of my price range for just the dv input
