panasonic dmr-e55 to sky+ help?
Discussion in 'Blu-ray & DVD Players & Recorders' started by andy007x, Sep 9, 2004.
  1. andy007x
    andy007x
    Can Anyone Help Me Please?,i Have The Above And No Matter What Leads I Use(2 X Cambridge Audio Rgb Scart Leads),there Is A Noticable Drop In Quality Compared To When I Connect Sky+ Directly.is This Some Form Of Interferance?can I Get Round This And Have Perfect Crystal Clear Picture?can You Guys Tell Me How To Connect The Damn Things Up?please.andy.
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,687
    Warwick
    +2,560
    Can you describe precisely how your connecting it up? What settings do you have in Functions/Setup/Connection? Ditto on the setup page of Sky+? What TV do you have and what settings are you using? Does the interferane occur only when the E55 is on (if it doesn't it is being caused by an external problem, i.e. a faulty scart lead or localised transmission)?
  3. andy007x
    andy007x
    have connected the sky+ and recorder as per manuals and using rgb scart leads to rgb scart port on sony trinitron tv,could it be video noise?is there a way around this?
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,687
    Warwick
    +2,560
    ...which don't tell you how to connect using the RGB socket on Sky. Ensure you hook up the TV Out on Sky+ to your E55. I need to know what your precise settings are (i.e. everything) before I can advise further though...
  5. pioneerman
    pioneerman
    Mar 25, 2004
    2,494
    surrey
    +63
    i recently brougt a seconhand e50 and i was pulling my hair out for ages,untill i reset the shipping condition then reset the rgb settings and presto solved it,hope this helps.
