Panasonic DMR-E55 & regular timer recording
Discussion in 'Blu-ray & DVD Players & Recorders' started by Teresamc, Nov 4, 2004.
  1. Teresamc
    Teresamc
    Hi - Newbie, please be gentle!
    I have just bought the DMR-E55 (I'm in New Zealand so not sure what would be different to UK version).
    In the manual there is a reference to daily and weekly recording - however there are no instructions on how to setup a daily or weekly recording. I can't see anywhere I could select daily or weekly in the timer recording setup screen. Does anyone have any ideas?
    Thanks in advance for your help.
  2. OARDVD
    OARDVD
    Jul 6, 2003
    241
    16
    Deepest Hertfordshire
    Welcome! :hiya:
    In the Timer screen place the cursor over the date field & press the down arrow several times. It will display individual days in succession (eg ‘SAT’, 'FRI’, etc). If you keep pressing, you'll get the following day ranges: 'MON-FRI', 'MON-SAT', 'SUN-SAT'.
    Good luck.
  3. Teresamc
    Teresamc
    Thank you so much - that's worked a treat.
    :clap:
